Higher than expected B+ from Hammond PT
All about iron and copper.
Kevin
Post by Kevin » Mon Apr 07, 2008 9:18 pm
I just finished building a JTM45-type amp - inspired by the Traynor Dynabass, actually - and my B+ is a good deal higher than I expected.
The PT is a Hammond 273BX which is rated at 350-0-350. I measured the AC voltage on the standby switch/recto socket at 354V, but I'm getting almost 490VDC on the plates. Before I put in the output tubes, I was getting 530 volts on the output sockets. :shock:
I'm just a little curious because the original JTM45 PTs are supposed to have been 350-0-350, but I think that they put more like 450 on the plates. Any ideas as to the discrepancy? The plate voltage is higher that my 350VCT, diode rectified 100-watter! And my caps are only rated for 500V.
Thanks for any insight.
Kevin
RACKSYSTEMS
Post by RACKSYSTEMS » Tue Apr 08, 2008 1:49 am
What is the current rating of the hv secondary? jtm 45s are about 150ma Dave
Maschinenmann
Post by Maschinenmann » Tue Apr 08, 2008 7:06 am
Which rectifier tube are you using?
User of the Wheel
chubs
Post by chubs » Tue Apr 08, 2008 7:38 am
Hammonds are renouned to be under rated. I would check your heater voltages.... I think hammond base their numbers on 110V mains.... so you can see that at 120... you can have higher numbers....
Kevin
Post by Kevin » Tue Apr 08, 2008 10:56 am
Thanks for all the responses.
The current rating is 175mA; so, maybe a little high? Would this "underloading" amount for higher plate voltages?
I'm using a Sovtek tube right now; it was the only one I could find in town. Will switching to an old Philips brand X lower voltage? Or even a new Chinese tube?
It seems that the Hammond is based on a 115V primary, so there's a few extra for me. The heater voltages are fine; 3.0-3.1. Yeah, Hammonds are known to be underrated. I figured specs is specs, you know. I guess I'll go with the next one down next time.
Maybe I'll have to buy a variac. Or try a 5U4, for kicks...
RACKSYSTEMS
Post by RACKSYSTEMS » Tue Apr 08, 2008 11:06 am
What tubes are in it and what are they biased at?
RACKSYSTEMS
Post by RACKSYSTEMS » Tue Apr 08, 2008 11:07 am
Oh yeah whats your wall voltage read?
Kevin
Post by Kevin » Tue Apr 08, 2008 11:14 am
Winged =C= 6L6GC, at 42-43mA, at 488VDC last time I checked.
Wall voltage is 120-121...
Thanks for the responses.
sebastiano
Post by sebastiano » Tue Apr 08, 2008 4:12 pm
Maybe your multimeter is not accurate.Check with other multimeters...
Kevin
Post by Kevin » Tue Apr 08, 2008 7:32 pm
It is a cheap meter; it would be nice the meter were faulty. It's probably not the case, though, as my wall and heater voltages are good.
I bumped the bias up to 48mA and the B+ is down to 478 - still pretty high for this style of amp...
Thanks again for the responses.
sebastiano
Post by sebastiano » Wed Apr 09, 2008 4:59 am
I have some experiences with some cheap multimeter,and despite correct values at low voltage,some HIGH voltage were incorrect...
Is not a big problem if your HT voltage is a bit high,maybe you have an amp with a little more headroom.....
Kevin
Post by Kevin » Wed Apr 09, 2008 3:00 pm
Actually, I've always found that the meter has a hard time with higher voltages; it jumps around for a while before settling down and giving me a proper reading. Maybe the high voltage readings are off. I'll have to get a better one soon...
No, it's not really a problem. With the preamp voltages adjusted accordingly and the appropriate filtering, it doesn't feel too stiff at all. :)
Thanks.
mathd
Post by mathd » Wed Apr 09, 2008 5:26 pm
i got a cheap digital multimeter here, when batt are low give fake result(higher usually) when they are fine, it's fine.
Kevin
Post by Kevin » Thu Apr 10, 2008 10:59 pm
replaced the battery - which was getting low - but i'm getting the same reading. maybe i'll look for an appropriate zener diode.
thanks for the responses.
kevin
razelfrax
Post by razelfrax » Fri May 02, 2008 7:37 pm
You could put a 180 to 300 ohm 10 watt resistor right after the rec diodes to bring it down .
