OK. Step 1 is strait forward enough. Check over your build list and parts.
Step 2 is somewhat different. The power transformers are laydown/drop-through/z-mount style. If you have an accurate PT like the Metro 1204-43 there should be 3 large solder posts on one side and 4 primary tabs (common-120-220-240) on the other. The primary tabs in 45/100s pointed towards the rear panel.
For the 1204-43, 45/100 PT you need to take the bolts that are already on the PT holding the top bell on, off, then use them to mount it to the chassis.
Steps 1 through 3 - Unpacking and installing the transformer
For the outut transformer mount it with the end bells facing the sides of the chassis, parallel to the tubes.
I put the side of the OT with the secondary leads (the side with 4 leads vs 3) facing away from the PT. The secondary leads are yellow, orange, green and blue I believe.
The choke I mount so that the side with the wires are facing the grommet they go through.
Im short on trany bolts so I wasnt able to complete this step
- 04-25-08_1139.jpg (102.16 KiB) Viewed 4315 times
- 04-25-08_1140.jpg (115.59 KiB) Viewed 4315 times
- gutpile
Here are some pics of my PT installation... BB covered the verbage pretty good above....
- (140.26 KiB) Downloaded 1689 times
- (145.6 KiB) Downloaded 1688 times
Metro Clips
- gutpile
Keep in mind that you will need to drill a hole for the HT fuse that goes behind the PT... I would suggest doing this right after you install the PT before you get too far along... pics to follow...
Metro Clips
my chassis has three holes(w/gromets) under the OT. what's the third hole for?
also, does metro sell a braket frame?
thanks Billy!
