HS-3 Di-Marzio
Post by yngwie308 » Fri Jun 06, 2008 1:41 pm
Yngve, my name is David Evan Llwelyn, my two middle names are of Welsh derivation, Evan and Llwelyn, was a famous Welsh warrior.
My father delighted in giving us 3 kids elaborate middle names. :lol:
I get a lot of my photos of Malmsteen from, search engines and of course the Yngwie forum and all over the net. I like to think that I am a tireless resource for all things Malmsteen and I have backed off lately from the intensity I used to be at.
Dave/Yngwie308
carlygtr56
Banned
Post by carlygtr56 » Wed Jun 11, 2008 9:56 am
I run my Reinhardt V-100 clean and use varius pedals for gain. The Yngwie Strats and pu's sound cool thru anything I've put them thru including fuzzes.
I dont shoot for an Yngwie tone.
I set my Yngwies up with different strings. One has a Jimi vibe. The other I got for a Blackmore vibe.
Post by yngwie308 » Wed Jun 11, 2008 11:34 am
I am looking to one day have a CS '69 which will be black and my black Hendrix Strat, My 2004 YJM is Hendrixy with the Yngwie setup, albiet slightly shallower scallops than his real '71's and '72's. I use the YJM Dean Markley strings that Carl dosen't like, .008 through .048 and I like it fine.
I need to play only this guitar to get more proficient on it, but I do love the scalloping, hard enough for me to chord with a flat fingerboard... :lol:
nevermind a scalloped one!!
I would sell my 1955 Martin in a heartbeat for a new Duck though, even though I will be probably $11K short :lol:
Carl Iknow this LP guy Dr.Vintage in Phoenix, he did my '52 Les Paul, he knows Reinhardt personally. Tell me about this V-100, is it a 100 watt plexi copy of sorts??
carlygtr56
Banned
Post by carlygtr56 » Wed Jun 11, 2008 1:25 pm
yngwie308 wrote:I am looking to one day have a CS '69 which will be black and my black Hendrix Strat, My 2004 YJM is Hendrixy with the Yngwie setup, albiet slightly shallower scallops than his real '71's and '72's. I use the YJM Dean Markley strings that Carl dosen't like, .008 through .048 and I like it fine.
Dave, the gauges of those Yngwie strings were cool, but I lost count of how many bullet ends popped off!!
I wish they did a BLACK Yngwie, like the black Strat he used in Alcatraz.
Bob Reinhardt is a great guy. The V-100 is a 100 watt version of his V-50. I saw a demo vid of the V-50 a few years back, that I thought had THE tone and he made me a 100 watt version of it.
http://www.vintageamp.net/ampfest/reinh ... tage50.wmv
The Vintage 100 is a 100 watt version of the Vintage 50. Big, bold and powerful, this amp will fill the largest rooms with tone. Built with a nice, deep, full tone, no icepicky harshness here. Our goal with the V100 was to try to recreate the old late 60's tones, while retaining the 70's grind, without the harshness associated with the 70's amps. According to the customers, we have accomplished that goal. I also have incorporated a vintage/modern switch into the amp. In the vintage mode, its thicker, and rounder, and in the modern mode, it gets clearer, with more attack. Gives you a nice variation in flavors.
This amp is a 4 input, non master volume setup, which is LOUD. It is the perfect platform for those who play the biggest stage, or those who like to get a good, loud punchy cleanish tone, and use pedals to shape your tone.
. The Vintage 100 has a killer, sweet full clean tone, and starts to get gritty around 4 on the volume. From 4 on up, it gets thicker and smoother crunch tones. As with all of our amps, it responds very well to the guitars volume control, and to your pick attack. When wound up, gets a nice gritty clean, or clean with a little hair on it, by rolling the volume back on the guitar. Go from there, to singing leads with just a turn of the guitars volume.
Power section is 4el34's, but you can also use 4 kt66's for the sweet tone that they give up as well. and the preamp uses 3 12ax7's. Solid state rectification keeps this amp tight, even when wound up.
Built with the same attention to detail, and high quality of all of our amps. Custom wound Heyboer OT, hand assembled and wired with Mil Spec PEC pots, ARS filter caps, "Dijon" and mallory and sozo coupling caps, NOS carbon comp resistors in all critical locations. Chassis are welded for extra support and durability, and switches are all heavy duty units for long troublefree service. I am constantly testing preamp tubes for the best possible combination of tubes.
I have also been testing the use of KT66's in this amp, and its amazing. All amps are now set up with the ability to adjust for KT66's, to give you that early Page,Clapton, etc type tone.
Standard on all amps is
Heyboer output transformer
Heyboer choke
Heyboer power transformer
PEC mil spec pots
Winged C or Mullard RI matched el34 power tubes.
A mix of Mullard, JJ, EI, or Tungsol preamp tubes.
NOS carbon comp resistors on plates and cathodes
"Dijon" , Sozo, and mallory coupling caps
ARS and Sprague high quality filter caps
Handwired with silver core teflon jacketed wire.
External bias jacks, with top mounted 10 turn bias pot for easy,
precise biasing.
Post by Tone Slinger » Wed Jun 11, 2008 1:34 pm
Glad to see a great player like his amp. But really Carl ,I bet you spank on a pignose too :D .
Yngve
Post by Yngve » Wed Jun 11, 2008 7:39 pm
Nice Amp!
Would string that you choose make it more mellow. Lets say using Ernie Ball Slinky what would be better.
Nickle Wound
or
Pure Nickle
Cheers Yngve
carlygtr56
Banned
Post by carlygtr56 » Wed Jun 11, 2008 8:54 pm
Yngve wrote:Nice Amp!
Nickle Wound
or
Pure Nickle
Cheers Yngve
Nickel wound strings are less bright I guess....or pure nickel. Try them out.
Yngve
Post by Yngve » Wed Jun 11, 2008 9:34 pm
What do you use? Might try pure Nickle
Post by yngwie308 » Thu Jun 12, 2008 12:26 am
Carl, is the Reinhardt V-100 in any of your clips, it sounds fantastic and the parts used are absolutely top notch and my fav transformers , Heyboers, and Dijon caps, is that like French mustards, and great parts all round. You say you use pedals with the 100 watt, what does it sound like opened up? It is described as a metal panel circuit, but with a sitch for a more plexi sound if I understand correctly.
Very nice and I heard Mark Knopfler is using Reinhardts now :) .
Very cool.I do see it listed in your clips after all.
Yngve
Post by Yngve » Thu Jun 12, 2008 3:00 am
How much are these heads worth, how different are they to our builds?
carlygtr56
Banned
Post by carlygtr56 » Thu Jun 12, 2008 6:05 am
yngwie308 wrote:Carl, is the Reinhardt V-100 in any of your clips, it sounds fantastic and the parts used are absolutely top notch and my fav transformers , Heyboers, and Dijon caps, is that like French mustards, and great parts all round. You say you use pedals with the 100 watt, what does it sound like opened up? It is described as a metal panel circuit, but with a sitch for a more plexi sound if I understand correctly.
Dave, The V-100 is in a ton of my clips. Check here for a gear rundown on my stuff-
http://www.soundclick.com/bands/default ... tent=music
Yes, the switch lets you toggle between the older mellower Plexi sound to a brighter gainier Metal Panal.
Opened up it starts distorting nice at about 4 on the volume. I have ran it thru a Hot Plate and opened it up and at the point no pedals were really needed, just a straight boost of some sort would work best.
I don't like attenuators though, so I ditched the Hot Plate.
carlygtr56
Banned
Post by carlygtr56 » Thu Jun 12, 2008 6:07 am
Yngve wrote:What do you use? Might try pure Nickle
Mostly Ernie Ball strings
Yngve
Post by Yngve » Thu Jun 12, 2008 8:56 am
What gauge strings? I though of putting 9 - 46's or 10- 46.
what do you think? i want more density
carlygtr56
Banned
Post by carlygtr56 » Thu Jun 12, 2008 9:50 am
Yngve wrote:What gauge strings? I though of putting 9 - 46's or 10- 46.
My white one I keep in E-flat and use regular 10-46
The blue one in standard tuning-...so far I've been using the Yngwie strings 8-46. So many ball ends snapped off, I'll never use them again.
I may just stick regular 9-42 on that one.
Yngve
Post by Yngve » Thu Jun 12, 2008 7:50 pm
Might try the 9-46 or the 10-46 want more beef in the tone and l usually end up with 10's.
Take care!
