Mynameisfritz wrote:What year is your Standard? And how big is the angle of the '61 RI?
My '68 is a totally different instrument, bigger angle and although in consequence the strings aren't parallel the strings, this thing sounds so amazing.
didn't you just write that ?
no neck angle on the 68' ?
didn't you say the pu's are not parrallel to the strings ?
if so, then there is a neck angle.
i have not found some pictures of late 60's sg's but i had in mind there was a neck angle !
i might be wrong, i will verify.
i have some pictures of a 1970' sg standard that seems to have a neck angle but i will check with earlier ones.
you really surprise me saying the 68' has no neck angle, cause on the picture you uploaded they have added that extra wood that seem to be (maybe it's just perspective of the picture, and it's flat !) in v shape (lying on the right side) ,giving the feeling they elevated the neck base (then forming an angle) , but if you're sure there is no angle, it might just be the illusion given by the picture.
so, if there is no angle on you 68'neck , then the pu's angle to the strings should be nearly the same as on the early/ mid 60's SG's with small pickguard; that is to say more or less flat
