Forming filter caps
- novosibir
Forming filter caps
Forming filter caps...
... isn't also a bad things for new caps and enhances their physically parameters, also when they've been (quick-) formed at the manufacturer.
But for new caps, which have been stocked on the shelf for more than 5 years it's obligation!
I'm describing the steps valid for a 100W Marshall, with the 45W or 50W models you can share some of this steps:
- pull out the power tubes and the preamp tubes
- disconnect the yello wire going from the PT between the first two filter caps, temporarily tape the unsoldered end for safety (100W only)
- unsolder each one lead of of the both 56K bleeder resistors across the both screen's filter caps and tape it temporarily for safety (100W only)
- disconnect the red wire from the rectifier diodes (the rectifier tube) to the first filter cap and swap in temporarily a 100K/1W resistor
Now fire the amp up completely (power & standby to 'on') and measure the voltage drop across the 100K resistor you've swapped in!
You'll notice, that first you'll have a voltage drop of about 200V, which within 15-30 seconds reduces itself to about 30-40V - then further on it is dropping slowly.
If so, all's ok and you can switch off your meter and do your other things, because now the caps require 4-24 hours time to form, depending on the cap's quality and the cap's age.
Only insure, that nobody else could get in contact with your 'open' amp - way the best is, to lock the room, where the amp is sitting and keep the key in your pocket. It's danger to the life for unskilled people!!!
From time to time you can check the process of the voltage drop - and as soon as the voltage drop across the 100K is less than 5V (five volts), your caps are formed.
Switch off the amp - and before you remove the swapped in 100K resistor, implicitly bleed the caps by connecting pin #1 of V1 with an alligator clip to ground for at least 2-3 minutes!
Now reset the temporarily tweaks and put in all the tubes again - you've done Fire up the amp and enjoy its (valorized) sound
Larry
BTW: Also when an amp hasn't been in use for longer than six months, you should form the caps, before you fire up this amp again! If not, the longevity of the installed caps might be significantly diminished!
Larry
- Flames1950
- novosibir
That's at least better, than not at all forming the caps.Flames1950 wrote:Larry, is it OK to simply pull the tubes (ALL of the tubes, unless you have a tube rectifier that is) and simply variac the amp? Start low and slowly increase every hour or so?
The first problem is, that with the variac you're limiting the voltage to the caps, and not the current - the current only is limited indirectly.
The second problem is, that you can't sense, how slow the caps need it to be formed or how fast you can proceed - you're deciding the process in this case.
The third problem is, that most of the people don't have so much patience, to regulate up the variac every 10-15 minutes a tad further, and that sometimes over a duration of up to 24 hours.
But the benefit of the resistor method is, that the caps are regulating all by itself - and you only have to check the proceeding result.
So why the stress with the variac?
Larry
- rockstah
right on Larry!novosibir wrote:Forming filter caps...
Larry
Re:
correct me if im wrong,
should i unsolder the red wire that goes from the rectifier to the mains filter cap and unsolder that wire on teh filter cap side? where should i connect the other lead of the 100k resistor? to the ground lug of the mains FC``?
- novosibir
Re: LCR dual caps with the Dummy terminal?
When you disconnect any cable from any solder joint, then suddenly you do have two contacts!
Right? The 1-st one still is the solder joint, the 2-nd one is the disconnected cable end.
And now swap in between both contacts...
Larry
Larry
aaaarrrrg let me get this.. ill make drawing here from my amp......
the balck block i painted is how you meant it? sorry im still a bit late here
- ddddddddd.JPG (83.4 KiB) Viewed 59996 times
- axeman
Can someone edit a 1959 layout, to be sure? I understand disconnect the yellow wire going from the PT between the first two filter caps.
Unsolder each one lead of the both 56K bleeder resistors across the both screens’ filter caps and tape it temporarily for safety (100W only)
Disconnect the red wire from the rectifier diodes (the rectifier tube) to the first filter cap and (swap in temporarily a 100K/1W resistor)
Are you saying to place a resistor between the red wire and the filter (main filter)?
- novosibir
The Resistor then is located between the rectifier and the first filter caps - temporarily, until forming is done.axeman wrote:Are you saying to place a resistor between the red wire and the filter (main filter)?
Larry
so the little drawing that i did was correct then huh?novosibir wrote:The Resistor then is located between the rectifier and the first filter caps - temporarily, until forming is done.axeman wrote:Are you saying to place a resistor between the red wire and the filter (main filter)?
Larry
- axeman
Sorry Larry, I need a visual aid. Retard.
axeman wrote:Sorry Larry, I need a visual aid. Retard.
hey neighbour. you do know me right? guess we`re on the same track here mate.
kahelle
- axeman
I buyed a batch of "NOS" LCR 50/50 dual caps and reformed in about 4-5 hours with a 22k series resistor.These LCR were from 1990 and never used,the voltage drop were no bad,about 10-15 volt at the start of the process a reduced it very fast.
Before learning to reform the caps,I made a terrible mistake.....I putted one of the NOS LCR in my amp as filter cap (JCM900 style pattern of filtering) and after 5-10 minutes the cap became a bit hot.....not a good thing.....With another cap,but reformed,this thing not happens.
