12xxxx Help.
- axeman
12xxxx Help.
I've been trying to make this amp sound like others in this form, and I can't figure it out. Today I rewired the power tube section and it actually did improve in tone, but still sounds horrible. May be one of you guys can figure it out by looking at these pic's.
- DSC00653.JPG (404.41 KiB) Viewed 4164 times
- DSC00652.JPG (368.8 KiB) Viewed 4162 times
- DSC00651.JPG (345.32 KiB) Viewed 4161 times
- DSC00650.JPG (341.79 KiB) Viewed 4162 times
- DSC00649.JPG (374.55 KiB) Viewed 4157 times
- DSC00654.JPG (417.54 KiB) Viewed 4152 times
- Omn
Re: 12xxxx Help.
As an overview these pictures are OK. But how about more detailed ones? Inputs. PI, or rather the whole area around; mains, fuses, secondary side of PT, outputs and ohm-switch...
Anyway. The best way would be to offer some measurements/readings. Not that I would be the one to ask, but that way someone will probably chim in.
The NFB-wire; where is it connected? Seems to be at the back of one output-jack, ending up at the center lug of the switch... I would rather go to one of the "ohm-lugs".
- axeman
Re: 12xxxx Help.
I use to have the NF wire at the impedance selector 8 ohm tap. Any way, the amp sounds like someone is playing the octave notes when I strum a chord. . Stand by for some more picks and Voltage reading.
- Scan.jpg (102.07 KiB) Viewed 4144 times
- DSC00656.JPG (306.85 KiB) Viewed 4099 times
- DSC00655.JPG (359.53 KiB) Viewed 4100 times
- axeman
Re: 12xxxx Help.
Ok guys, I rewired the power board and there was a drastic improvement. It sounds spongy now ( when I jump the channels) I need some one to post a clip to compare tones. Please
- MarshallGeek
Re: 12xxxx Help.
Wiring the NFB to the speakeroutput will put the NFB to the selected impedance setting.
The "octave" notes you're hearing sounds like a parasitic oscillation problem...
Try to run the purple wire coming from the NFB resistor under the board, and let it come out on the far end of the circuitboard where the positive ends of the biascaps are located. The last turretboardpost will be the "exitpoint" of the purple wire.
The silver mica cap on the PI, correct me if I'm wrong, shouldn't that be a 47pF? Yours is a 100pF...
New School, Old School, hell I don't go to school!!
'72 JMP 1959
'73 JMP 1959
'89 1962 metro PTP
'77 JMP 2203 metro PTP
'72 JMP 1959
'73 JMP 1959
'89 1962 metro PTP
- Omn
Re: 12xxxx Help.
That is fine. But it is also a limitation when it comes to tweaking. Loose (4 ohm) or tight (16 ohm) is not a choice anymore.
Another limitation is the use of a "normal" standby-switch instead of the triple toggle. Many find the 80% to their likings.
I would not twist the CT of the heater around the heater wires, but rather straight to ground. But who am I?
And I would trim the wires sticking up like soar thumbs in some of the connections. They are antennas.
- axeman
Re: 12xxxx Help.
Thanks MarshallGeek, I'll try rerouting the NF wire like you recommended, and as far as the Fizz mica cap, 100pf is what Eddie used on his amp. I don't think that's a problem.
Omn, I'm going to move the ct for the heaters and send it straight to ground.
- Omn
Re: 12xxxx Help.
Not sure that will do anything for the sound..., mingling more with the power trace than the sound trace.
There was a great thread earlier where Rockstah took someone (can not remember who) through some intense tweakings with an excellent result. You might find some good things there. I tried searching for it but gave up...
Here you have a nice 12xxx http://forum.metroamp.com/viewtopic.php?f=16&t=22611" onclick="window.open(this.href);return false;
- axeman
Re: 12xxxx Help.
Thanks OMN. It sounds a little bit better.
- wdelaney72
Re: 12xxxx Help.
The ground from your AC in needs it's own isolated lug. I use one of the Metro single hole ground lugs and mount it under the PT mounting bracket for the AC ground.
Walter
- axeman
Re: 12xxxx Help.
Thanks wdelaney72. I'm going reroute the ground.
Re: 12xxxx Help.
So wait, did the issue ever get resolved? I like your style axeman, not doing the whole low voltage option. Im considering building a 12xxx just the same way (with the standard SPDT stand-by switch as opposed to the VH aficionado 3P3T "Rudolph's Red-nose" switch). So I'd love to hear that this issue was/is resolved.
"Seldom give unguarded advice, for advice is a dangerous gift, even from the wise to the wise, and all courses may run ill."
- axeman
Re: 12xxxx Help.
Thanks buddy. (itsonlyadam) The amp sounds better, but I believe what I have now, as far is tone, is not it's true tone. So what I did today is dismantle the beast and ordered some wire, power transformer plate and some Sozo cap's from Fido ( that guy is to COOL) so I can start over again. Any way here's a clip of what it sounds like .
http://www.youtube.com/watch?v=VuYFqLtY ... annel_page" onclick="window.open(this.href);return false;
- Fido
Re: 12xxxx Help.
Hey bro, thanx for the props...you rock as well. When will you post an updated clip of the re-tweaked amp?axeman wrote:So what I did today is dismantle the beast and ordered some wire, power transformer plate and some Sozo cap's from Fido ( that guy is to COOL) so I can start over again. Any way here's a clip of what it sounds like .
Fido Kennington
Exile On 12th Street
http://www.bullhonky.com" onclick="window.open(this.href);return false;
- demonufo
Re: 12xxxx Help.
Ah, that would be this one then. Absolutely the most essential guide for anybody serious about tweaking one of these. I'm not suggesting that you should absolutely follow every detail to the letter, but at least you can hear the results of everything, and decide what is for you.Omn wrote: There was a great thread earlier where Rockstah took someone (can not remember who) through some intense tweakings with an excellent result. You might find some good things there. I tried searching for it but gave up...
http://forum.metroamp.com/viewtopic.php ... g+rockstah" onclick="window.open(this.href);return false;
So I like purple, okay!!!!!!
