Need some JCM 800 100 watt PT wiring info please.
newbie
Post by newbie » Mon Jul 13, 2009 7:09 pm
I'm building a jcm 800 100 watter 2203 schematic but running EL34's(220K bias splitters). I'm using CE distribution/AES power transformer P-TM-P100 which only has a 350vac B+ secondary winding(thats 350 total, 175 each leg).
My confusion comes from the many different online schematics that show different PT wiring. Some show a bridge style rectifier, have the CT going to two 100uf caps between ground and rectified B+, and utilize the bias winding for bias. Others show four non bridge diodes, a grounded CT, and pull the bias from one leg of B+ ac. Others have variations of both.
My question is, what is the correct way to wire my PT to get correct B+? I would assume a non grounded CT, standard 4 diode bridge rectifier, and use the bias winding for the bias?
Thanks ahead of time on my first post ever.
axeman
Re: Need some JCM 800 100 watt PT wiring info please.
Post by axeman » Mon Jul 13, 2009 7:19 pm
look here http://forum.metroamp.com/viewtopic.php?f=28&t=25151" onclick="window.open(this.href);return false; Don't let Larry find out you didn't introduce your self. :shock: :lol:
newbie
Post by newbie » Mon Jul 13, 2009 7:38 pm
Thanks for the link, but while I can see the diode layout I can't see how it is actually wired in reference to the two 100uf's on the CT and the bias hookup. Is there a schematic that was followed that I could see?
As for introducing myself, I was so anxious to get an answer I forgot too!
axeman
Post by axeman » Mon Jul 13, 2009 7:46 pm
The white wire is your bias wires, the two black wires are heater wires, the two green wires are ground, the gray and blue wires are going to your stand by switch (bottom) the yellow wire is going to the 100 uf (the mains filters) the primaries are obvious I hope.
"As for introducing myself, I was so anxious to get an answer I forgot too"!
You better do it because Larry haves no mercy. :lol: :lol:
newbie
Post by newbie » Mon Jul 13, 2009 7:55 pm
So you are saying that it's wired like this then?
Bias from PT winding, B+ CT to two 100uf caps, and full wave bridge recto?
Why wouldn't it be better to ditch the two 100uf's on the CT and just leave the CT ungrounded like the 50 watter? I mean PS filtering from the remaining three 50/50 caps cans is more than adequate isn't it? Why is the CT neither ungrounded or grounded in that schemo?
axeman
Post by axeman » Mon Jul 13, 2009 7:59 pm
What are you trying to do, and what schematic are you using. Show us some pictures, more people will help. So is it a 2203?
newbie
Post by newbie » Mon Jul 13, 2009 11:34 pm
I'm now asking if the two 100uf caps are necessary as most bridge rectified amps simply don't hook up the CT and leave it disconnected. If I'm using the three 5r0/50 cap cans in the power supply rail, wouldn't leaving the CT disconnected do the same thing? Just trying to educate myself here.
axeman
Post by axeman » Tue Jul 14, 2009 12:08 am
If you are building a 2203 you need 6- 50x50 uf caps, and you have to connect the ct.
newbie
Post by newbie » Tue Jul 14, 2009 1:15 am
Some of the schematics would indicate that...........So what is this then?
http://www.schematicheaven.com/marshall ... w_2203.pdf" onclick="window.open(this.href);return false;
I thought at first it's the difference between the 1959 2203 & later 100 watt lead 2203............until I saw this one.
http://www.schematicheaven.com/marshall ... w_1959.pdf" onclick="window.open(this.href);return false;
So my question is, if these are in fact original marshall 2203 schematics as it states at the lower corner, and they do not utilize the two 100uf CT connection(ct not used at all like a normal bridge ss rectified amp)
What makes the ones showing it the other way more correct?
axeman
Post by axeman » Tue Jul 14, 2009 1:24 am
The 1959 2203 had 3 caps. But thats not a 1959 :oops: The second schem is. Someone else will follow up on your question.
2203zw-60-02.pdf
(93.09 KiB) Downloaded 965 times
newbie
Post by newbie » Tue Jul 14, 2009 1:35 am
Thanks for your help High Decible.........I'm just going to build it with the 6 caps. I'm not sure I see the need, but it'll make life easier I suppose! :)
paulster
Post by paulster » Tue Jul 14, 2009 4:44 am
With the -V side of the bridge rectifier connected to ground and the +V side being B+, the centre-tap of the transformer is then at 1/2 B+ voltage.
This is tied to the junction of the two sets of caps to ensure that they both have equal voltage across them, rather than one jump over its voltage rating by having a different internal resistance.
You don't need to connect the centre-tap, but if you don't you should use a pair of resistors to balance the voltage on the caps, as in the screens supply node.
newbie
Post by newbie » Tue Jul 14, 2009 5:54 am
Thanks Paulster, thats exactly what I had intended to do. Not connect the CT and add the lost PS capacitance in the power rail downstream of the stby switch, which mine is after the bridge and not like the original. My main reason was to save a few $ on 50/50's. I just finished wiring it with the 5 cans(used one 100/100 can and 4 50/50's) and all is right with the world.
Thanks for the help guys.
uiovbged332
Post by uiovbged332 » Wed Jul 06, 2022 9:12 pm
Nike Air More Uptempo
Nike Air Max 720
Jordan 11
Air Max 270
Nike Shoes
Nike Huarache
Nike SB Dunk
Cheap Jerseys
Nike Lunarlon
Jordans 6
Nike 270
Jordan Retro 11 Low
Pandora Jewelry
Jordan 11 Concord
Jordan 14
Wholesale Adidas Sneakers
Jordan 24
Nike Air Force
Air Jordan 13 Retro
Pandora Bracelets
Adidas Shoes
Pandora Ring
Jordan 27
Nike Shoes
Pandora Jewelry 70% off Clearance
Nike Roshe
Nike Flip Flops
Jordan AJ 1
Jordan 29
Jordan 12
Nike Air Force 1
Jordan 2
Adidas Yeezy
Jordan Retro
Jordan 32
Jordan 25
Air Jordan 4
Nike Factory Outlet Store Online
Adidas Yeezy
Wholesale Air Jordans
Nike Acg
Pandora Charms
Air Force 1s
Nike Outlet
Nike Zoom
Nike Running Shoes
Jordan 28
Pandora Jewelry
Air Jordan
Nike Outlet Store
Cheap Jordan Shoes
Air Force 1
Air Max 2019
NFL Shop
Air Max
Air Jordan Shoes
Nikes
Jordan 17
Air Jordan 33
Nike Hyperdunk
Christian Louboutin Shoes
Jordans 26
Jordan 30
Off White Nike Shoes
Huaraches Shoes
Nikes Wholesale
Jordans 2021
Nike Blazer Mid
Air Jordan 34
Nike Wholesale
New Nike Shoes
Air Jordan 11 Retro
Adidas Store
Wholesale Nike Shoes
Jordan 12 Retro
Nike Air Jordan
Wholesale Jordans
Jordan 13
Nike Air Force 1s
Nike Outlet
Dior Jordans
Nike Canada Outlet
Kids Jordans
Cheap Jerseys From China
Nike Air Max
NHL Jerseys
Wholesale Clothing
Adidas Wholesale Distributor
Nike Store
Nike Shox
Jordan 16
Adidas Factory Outlet
Jordans 19
Jordan 21
Nikes Shoes
Nike Jordan 1 High
Jordans 33
Nike Women's Shoes
Nike Shoes
Nike Wholesale Suppliers
Official Nike Outlet Online Store
Nike Free rn
MLB Jerseys
Jordan 18
Nike Shoes For Women
Jordan 22
Pandora
Nike Sneakers
Nike Zoom
Cheap Nike Shoes
Jordan 15
Baby Jordans
NBA Jerseys
Air Jordan 35
Jordan 33
Rings Pandora
Nike Factory Outlet
Nike Air Force 1
Adidas Shoes Canada
Cheap Jordans Free Shipping Wholesale
Huarache
Fjallraven Backpack
Air Jordan 5 What The
Nike Shoes Black Friday
Jordan 20
Nike Wholesale
Nike Running Shoes
Jordan 23
Nike Clearance Outlet
Cheap Jordans
Adidas NMD R1
Cheap Jordan Shoes
Lebron Shoes
Cheap Jordans
Cheap Nikes
Raptors Jersey
Red Bottoms Louboutin
Jordan 12
Pandora Jewelry
Nike Outlet
Nike Free Run
Men Nike Shoes
Pandora Jewelry
Nike
Jordan 31
Wholesale Shoes
Jordan 1
Cheap Nike Shoes From China
Yeezy Boost 350 V2
Nike Canada
NHL Shop
