hi,
can I use the 4 and 8 ohms secondaries at the same time, running two different caps? this is with a fenderish ot. thanks?
running two ot secondaries at the same time
- Structo
Re: running two ot secondaries at the same time
I believe it would make the secondary impedance about 2.6 ohms if you were to combine those two taps (4 &
And when you said caps, I assume you mean cabs?
Tom
Don't let that smoke out!
You can, but you want to use an 8ohm and a 16ohm cab on the 4ohm and 8ohm taps respectively to do this and retain the correct impedance matching.
This is effectively the same as running 2 16ohm cabs off the 8ohm tap or 2 8ohm cabs off the 4ohm tap.
thanks a lots!paulster wrote:You can, but you want to use an 8ohm and a 16ohm cab on the 4ohm and 8ohm taps respectively to do this and retain the correct impedance matching.
structo, yes I meant cabs
