lower capacitance shield wire
5150loveeddie
Post by 5150loveeddie » Mon Jul 19, 2004 2:42 pm
Lower capacitance keeps the high impedance signal from losing highs?
George?
Post by VelvetGeorge » Mon Jul 19, 2004 2:46 pm
That's correct.
This is more of a concern in long cables, like guitar cords.
Any high quality coax should be fine for inside your amp where the runs are typically less than a foot each.
5150loveeddie
Post by 5150loveeddie » Mon Jul 19, 2004 3:39 pm
Cool,
Would you have a picture of an amp with the post inverter Master Volume installed afterward (like I will do....)
You've send me with the kit a small 3 terminal bar and was woudering how to use it properly.
BTW I've used shielded wire for V2 PIN2 with the shieldering to the plate and the amp is so low noise now with treble, mid at max and high volume settings....cool
The only thing I wish to fix still is when the presence pot is increase there's a little buzz noise.........JF
