Fizz/Treble Caps - Composition and Sound
Kramer
Post by Kramer » Mon Dec 21, 2009 12:27 am
Hey everybody, I'm getting back into researching the specifics of my next build, and something that isn't talked about a whole lot or seems to be eluding me is what kind of capacitors (used in PI and treble positions) generally sound good/generally sound bad/generally sound like this:, etc. So what do you all prefer? There are the normal silver micas that you can get for real cheap and then ceramics which are also cheap, and then you can get into the NOS variants of those two types which can range up to $20 per cap. I've seen a few people using the Lemco Silver Micas, so what do you people think about them? What have you guys found makes a difference, or is there really no difference at all with these things?
Many Thanks, and Happy Holidays!
alex
Re: Fizz/Treble Caps - Composition and Sound
Post by VelvetGeorge » Mon Dec 21, 2009 7:36 pm
I love old single layer ceramic disks or old stock silver micas. Modern silver micas are decent too. Modern ceramics are mostly bad sounding to my ears.
Roe
Post by Roe » Tue Dec 22, 2009 8:47 am
I'm not happy with modern silver micas for the plexi sound - they sound too smooth and lack the aggressive snarl of old plexis. some of the higher voltage reading ceramic caps can be nice, they have a dirtier sound without sounding as harsh as the lover voltage ceramics.
I've pretty much replaced all these treble/fizz caps lately in my plexis, partly with nos tonebone lemcos. I'm much closer to the aggressive marshall snarl now
shakti
Post by shakti » Tue Dec 22, 2009 8:58 am
So the cap type in the PI matters too, huh?
On the same subject; how high can you go with the fizz cap value before it starts to roll off high end? 56pF? 70pF? 100?
Kramer
Post by Kramer » Tue Dec 22, 2009 3:47 pm
From what I've heard the PI cap certainly does matter; a few people like to use 100 pF. See this thread for more info.
Where did you source your Lemco's from Roe?
Roe
Post by Roe » Wed Dec 23, 2009 4:49 am
I got several of ebay over the last two years. also a few from rich m at plexipalace
Roe
Post by Roe » Wed Dec 23, 2009 8:14 am
Kramer wrote:From what I've heard the PI cap certainly does matter; a few people like to use 100 pF. See this thread for more info.
yes, 100pf will give less highend than 50pf. but what about 68pf etc?
and more importantly (in the context of this topic): will the type of cap make an difference?
myfoot
Post by myfoot » Wed Dec 23, 2009 8:35 am
Roe wrote:I got several of ebay over the last two years. also a few from rich m at plexipalace
Isn't that Sparky from here?
Roe
Post by Roe » Wed Dec 23, 2009 9:36 am
No, not as far as I know
shakti
Post by shakti » Wed Dec 23, 2009 9:41 am
Yes, sparky and Rich M is the same person. Great guy to deal with!
Back on topic...what do people find when changing...
- tone stack treble cap from silver mica to ceramic (the 250 or 500 pF one)
- PI "fizz" cap from silver mica to ceramic (the 47 pF one)
...and how much higher than 47pF can you go before the high end gets rolled off to a noticeable degree?
Roe
Post by Roe » Wed Dec 23, 2009 9:46 am
I can easily hear the difference when it comes to the 500ish cap on the mixer resistor as well as the 250/270/470 cap in the tone stack. the new silver micas (most of which I got from metro) sound too polite and smooth. some newer ceramics, sounds harsh. but some sound pretty good.
before I found some NOS stuff I used metro's ceramic across the mixer resistor and the silver mica in the tone stack
Kramer
Post by Kramer » Wed Dec 23, 2009 4:57 pm
I saw these and thought they looked good..maybe not NOS ball park, but maybe a step over the normal silver micas.
http://www.tubeampdoctor.com/index.php? ... 0719f6722c" onclick="window.open(this.href);return false;
Roe
Post by Roe » Thu Dec 24, 2009 10:03 am
It been a while since I tried the TADs but I dont remember the TADs being better than the silver micas george sells.
RockingJTM
Post by RockingJTM » Thu Jan 21, 2010 5:38 am
Is it also possible to use NOS mustards instead of silver mica caps or ceramic caps.
Does anyone try this yet? and how does it sounds?
PCollen
Post by PCollen » Sun Jan 24, 2010 5:52 pm
68 pf will give a little more highend than 50 pf, and a little less than 100 pf.... :roll:
