Post
by J-Sty » Wed Jun 23, 2010 2:19 am
I had a question about this and I figure this is as good a place as any to post it...
The HT fuse Center tap originally connects with the OT center tap and Choke at the spare board turret. When you reroute the HT fuse center tap to the ground at position 5 with with the main caps and rectifier diodes, do you also place the OT center tap and choke at this location?
Essentially I'm saying is it HT Fuse Center, OT Center Tap, Choke, Mains, and Rect. Diodes on ground 5? Or just diodes, Ht fuse Center, and Mains?
If the OT Center tap and choke don't go on ground 5, do they just connect together like normal?
Any info would be greatly appreciated, as I didn't see this discussed on any other grounding posts.
"I never really tried to copy anyone when I sang, until my voice eventually evolved into the girlish whine it is today" -Robert Plant
