Can anyone suggest a power and out-put tranny of no more then 10-15 watts that would work in a push-pull circuit? I am building a Mini Plexi, and will be using almost the same circuit as its bigger brother. Also, I plan to incorporate the Larry Tube Effects Loop in it. So my power tranny needs to support 4 12AX7's and two EL84' (or 6V6's).
Please keep in mind that I know of Hammond and Mercury Transformers. However, I need an out-put transformer that can almost replicate (or just plain sound good) like the C1998 Dagnall (I've had slight experience with both Mercury and Hammond trannys. Although they are great, they still miss the sound I'm after). Again, my mission is to build an amp that can be used at home without destroying the neighbor's windows
Does anyone know if Heyboer or M e r r e n make something I'm looking for?
All help is appreciated.
Thanks,
Ed
