mission amps tweed deluxe (help)
robbygray
Post by robbygray » Tue Apr 21, 2009 10:29 pm
So, I put this little devil together a little while ago, but shes been giving me quite a hard time. I'm running into some major hum/grounding problems??? With the amp turned fully up, its just screaming with hiss. Plus, when I hit the low E, the amp is producing a kind of broken sound. Not in the cool, tweed deluxe/neil young broken kind of sound, just bad. :? Some alterations from the original kit would include the mercury magnetics 59 OT. Any advice would be so very greatly appreciated.
P1020990 resize.jpg (364.66 KiB) Viewed 1838 times
Charlie415
Re: mission amps tweed deluxe (help)
Post by Charlie415 » Fri Apr 24, 2009 5:58 pm
I wish I could offer some help but to be honest I really don't know enough about electronics to help. Maybe if you posted something besides pictures somebody here could help - schematics, what you have done so far to try and fix the problem etc..
Good luck...
Twistingcrow
Post by Twistingcrow » Sat Apr 23, 2011 8:56 am
Hi there!
I'm about to take the plunge and buy a Mission Amps 5E3 kit. Have you solved your problem and what's your feedback on the kit and the amp's tone ?! Would you recommend Mission Amps?
Thanks!
rcol1325
Post by rcol1325 » Sat Apr 23, 2011 10:59 am
Sorry, thought I could help. I better not even try.
SteadyEddie
Post by SteadyEddie » Sat Apr 23, 2011 1:35 pm
In my experience, when I come across hiss, it's usually a preamp tube. Sometimes you just get bad ones. Try swapping some around and see if that makes a difference.
