JEN Crybaby
- ohmygodtheykilledkenny
JEN Crybaby
I can buy one for 100$, apparently working. Made in Italy, model 310.001.
Worth checking out?
Worth checking out?
If yer ears ain't ringing, yer amp ain't singing! -JimiJames
Re: JEN Crybaby
Alright, picked it up for $80! Red fasel, has the Ducati non-polarized cap.
Swapping the white box shaped 0.22uf caps for a pair of 100v Mullard Tropical Fish. Just rebuilt the switch.
I'll post clips of it once I get a chance to post clips of my latest homemade fuzz.
Edit: also swapping the trannies for a pair of NOS BC108's.
Travis
Travis
Re: JEN Crybaby
This wah is so sick. It needs new trannies though, very hussy mid sweep. The only problem is that I'm having trouble determining the pinout of the Bc170b. Hints?
Re: JEN Crybaby
Google the data sheet for that transistor, I have BC108c s in my Experimental Clone Wah, try wiring a 100k mini pot in parallel with the the inductor where the 33K/100K resistor goes and then you can tweak the Q to get the best sound
PS: If you have carbon comp resistors check them with an ohmeter to make sure they are within spec so your transistors are not biased too hot
Re: JEN Crybaby
Hey man, thanks for the reply! They are mostly carbon film, couple are pihers, though that is on the to do list. I've looked everywhere man! No datasheets with pinouts!
Re: JEN Crybaby
Swapped to Bc108's, now the wah is very weak and quieter, hfe of the transistors was about 420. I've got shows this weekend so I can't do anything till Sunday at the earliest but does anyone know what could be the problem? I can post some pics on Sunday if that would help.
Thanks,
Travis
Thanks,
Travis
- yngwie308
Re: JEN Crybaby
The Jen Crybaby I purchased new from Jim's Marshall shop in London back in 1969, still the best wah I have heard, Vox, you name it.
Worth saving.
Worth saving.
Re: JEN Crybaby
Mhm! I gotta swap transistors again. It sounded amazing but noisy, then I installed one bc108 with the wrong pinout and after correcting it the wah sounded really weak. So I think I probably fried one.
- HTH
Re: JEN Crybaby
all those old metal cans with the tab on the side are EBC from the tab and looking at the bottom of the transistor.
if you have a DMM with a diode function you can work out what the pinout is, it's just two diode junctions after all.
- garbeaj
Re: JEN Crybaby
I'd love to see a pic or two:)
Re: JEN Crybaby
I did know that actually, but I thought the original transistor had a different pinout (couldn't find a data sheet). I have several more bc's kicking around so I might get it done this weekend.HTH wrote:all those old metal cans with the tab on the side are EBC from the tab and looking at the bottom of the transistor.
Pm me your email and I'll shoot you gut shots.garbeaj wrote:I'd love to see a pic or two:)
- garbeaj
Re: JEN Crybaby
I wasn't so much interested in the guts as the outside of the pedal...I'm a very superficial personohmygodtheykilledkenny wrote:I did know that actually, but I thought the original transistor had a different pinout (couldn't find a data sheet). I have several more bc's kicking around so I might get it done this weekend.HTH wrote:all those old metal cans with the tab on the side are EBC from the tab and looking at the bottom of the transistor.
