Help Implementing Star/Larry Grounding scheme
Roe
Re: Help Implementing Star/Larry Grounding scheme
Post by Roe » Wed Aug 11, 2010 2:10 pm
pvan339 wrote:If the bus wire is not soldered to the back of the pots with the Star/Larry grounding system, does the back of the treble and bass pot need anything done to them?
no
chetz
Post by chetz » Sat Jan 01, 2011 8:24 pm
wildebassman wrote:Hi mate!
"but the point is to have the loops spread out, and be as close to a line in their positioning as possible."
Cheers,
Dennis.
A ground wire is coming off the back of the PI and is being grounded at point #3. Does that wire come off the negative terminal on the PI? Just want to make sure.
Got this project geared up again! Thanks for the help.
Jeff
Xplorer
Post by Xplorer » Fri Jul 13, 2012 10:06 am
Hi !
i'm about to build two JTM45/100 and another superlead69.
about the JTM45/100, i'm still a bit uncomfortable in my understanding of the larry's grounding. I'd be affraid to do some mistakes. Did anybody create a layout, applied to this specific amp ?
i'm thinking of doing this, based on Billy batz's layout, so i'd just have to make sure it's ok, and then follow the design while building it.
thanks for this topic.
hotguit
Post by hotguit » Fri Jul 26, 2013 6:01 am
HI
I'm going to rewire my jmp '78 2204, which is very noisy, according to Larry's grounding scheme.
But I'm a bit confused; must not the sub stars points be linked togheter by a ground bus which IS ISOLATED by chassis and goes to ground in ONE POINT ONLY (at input jack)??? (SEE ATTACHEMENT)
In the pics of jtm 45 ground scheme each cap goes to ground in its own point; is it right? in it an alternative way of doing the grounding or what?
Who can explain me?
Thank you so much
hot
groundscheme resized.jpg (51.04 KiB) Viewed 16598 times
LIFE IS TOO SHORT FOR A BAD TONE!!
Post by neikeel » Fri Jul 26, 2013 10:32 am
Larry's grounding is not a centralised common earth rail
Each section has its own dedicated earth to the chassis:
Preamp
PI
Screens
Mains
Input etc
Essential that the input ground is dedicated to chassis, nothing else
also the heater centre tap is tied to the guitar input jack ground.
Both those things make the biggest change in my testing.
hotguit
Post by hotguit » Sat Jul 27, 2013 10:23 am
Thank you neikeel very very helpful reply
Thank you
hot
hotguit
Post by hotguit » Sun Aug 04, 2013 11:25 am
Hi nobody has a scheme i can apply to a jmp 2204?
thank you
hot
Wattever
Post by Wattever » Sat Dec 21, 2013 9:42 pm
I'm FINALLY getting started on assembling my JTM45, and I just have a few things that I want to clarify before I start cutting wires and drilling holes. :scratch:
In the picture way back on page one of this thread, I can see that the new ground wires are added, and the old ones aren't removed, but the input grounds are a bit confusing. I assume, that the "stock" ground wires go to the new #1 ground point, but the picture seems to show the grounds coming off the tip (rear terminal) of the jacks.
Another thing that I'm not sure about, is how to ground the bottom of the cap on the back of the presence pot. Should it "V" back to terminal one on the pot, or to one of the new grounding points? (I would guess it would be #3.)
Aside from those two things, I think it should be reasonably smooth sailing... at least til the smoke starts rolling out of it. :shrug:
frusciante89
Post by frusciante89 » Sun Jan 05, 2014 2:18 pm
Hi guys, I'm almost done with my 1987... I just found out about the Larry grounding, and it's too late to drill holes :/ Can I use the transformers screws and the board screws for the ground lugs? Will there be interferences? Another thing: will the paint on the chassis create problems with grounding? :peace:
Indifferent
Post by Indifferent » Thu Mar 28, 2019 5:51 pm
Hi all,
I am looking for the most current image of Larry's original grounding scheme for the JTM45 Metro build. Can someone point me to it?
Thanks,
John
SPeter
Post by SPeter » Mon Apr 15, 2019 1:36 pm
This layout shows everything
haig
Post by haig » Sat Jul 04, 2020 10:31 am
I’m looking for the most recent grounding layout, but there doesn’t seem to be any on this thread. Can someone please reupload one?
finom1
Post by finom1 » Fri Jan 21, 2022 12:45 pm
Does anyone have the PDF that explains the Star/Larry Grounding scheme???
Thank you.
Yaron
Post by Yaron » Mon Apr 10, 2023 8:13 pm
I have this
