Satriani board and guitars.
vanhalen5150
Re: Satriani board and guitars.
Post by vanhalen5150 » Thu Oct 24, 2013 10:51 am
I just realized from this photo. I thought it was piece of tape but that little square on the back is actually a battery door for the sustainiac PU. Thats also around where the input jack is located. Not on the standard model.
JimiJames
Post by JimiJames » Thu Oct 24, 2013 12:18 pm
vanhalen5150 wrote:"...Not on the standard model..."
Looking at that neckplate, contour & skunk stripe, a late 80's Fujigen.
Not in Joe's model, but Sustainiac IIRC, was around several years before that guitar was made,
but easily could of went through a Hoshino Rep, or factory direct, to do the stock mod later down the road. Or not.
Could of been done anywhere at any time. :shrug:
Satchmo's G3 brainchild has morphed several times through some great musicians & performances
spawning B3. It was kool seeing Jeff, Billy & Stu's Bass version of G3.
(Seen Marco Mendoza do B3 by himself) :shock:
Build'sClip'sVid's
vanhalen5150
Post by vanhalen5150 » Thu Oct 24, 2013 12:26 pm
That is is the original prototype above. The other one he has in this color had a huge wide skunk stripe that went all the way up through the headstock. Had the Sustaniac PU as well added. Made in Japan.
The little horn is totally new design I guess. Major cut away as he went to 24 frets. The whammy bar is graphite.
JimiJames
Post by JimiJames » Thu Oct 24, 2013 12:58 pm
So from a JS1200 or JS100 to a JS24... Awesome they (Ibanez) were able to accommodate Joe...
ahh heck I give up. I've been trying to get a Stratocaster body to fit a 24 fret neck, aware that the horn will be cut deeper for access & slightly shorter body, but still unable to find a company short of going through Fender's CS. :?
Build'sClip'sVid's
vanhalen5150
Post by vanhalen5150 » Thu Oct 24, 2013 1:19 pm
The single coil on this one can be split as well as the bridge humbucker. He put in the smaller humbucker because a regular sat too far down the body because of the extra frets.The second knob is a hi/lo frequency cut when pulled out.
rgorke
Post by rgorke » Fri Oct 25, 2013 4:35 pm
Not sure this is the right place but here is a cool interview/lesson by Joe.
http://www.youtube.com/watch?v=GvFK-0ifBQo#t=2263" onclick="window.open(this.href);return false;
