![Image](http://i169.photobucket.com/albums/u223/fusionbear/Igor%20Transformation/KIMG0055_zpswma6eodn.jpg)
This one shows the .1 Sangamo's that I replaced with .039 mustards:
![Image](http://i169.photobucket.com/albums/u223/fusionbear/Igor%20Transformation/KIMG0048_zpszgbdde60.jpg)
The amp sounds awesome...
It is a Lo-Vo 400B+ on the plates and can take 6550's or EL34's
Yes sir, stock....danman wrote:Looks great! I was wondering if you stick to the standard values 470pf/470k on the input?
coldengray wrote:Nice work Carl! What are you using for the red solder joint paint?
Nice. Sounds great.
I know that place. Been there a few timesfusionbear wrote:coldengray wrote:Nice work Carl! What are you using for the red solder joint paint?
http://www.vetco.net/catalog/product_in ... AmZo8P8HAQ
Thanks Carl, I might order some. Clip sounds great!fusionbear wrote:coldengray wrote:Nice work Carl! What are you using for the red solder joint paint?
