JVM 205/210 schematic?
Does anybody have the schematics for the JVM 205/210 amp?
- novosibir
Re: JVM 205/210 schematic?
You only have to scroll a bit down on the Board index, then you'll find a forum "Marshall Schematics"Mats A wrote:Does anybody have the schematics for the JVM 205/210 amp?
Larry
Thanks!novosibir wrote:You only have to scroll a bit down on the Board index, then you'll find a forum "Marshall Schematics"Mats A wrote:Does anybody have the schematics for the JVM 205/210 amp?![]()
Larry
But I find only the 410 schematic there and the JVM 205/210 is quite a different beast.
Here you go
- JVM210-67-02-v01.pdf
- (63.9 KiB) Downloaded 2484 times
- JVM210-61-02-2-v02.pdf
- (124.15 KiB) Downloaded 1928 times
- JVM210-61-02-1-v02.pdf
- (60.71 KiB) Downloaded 1782 times
- jvm205-65-02-iss3.pdf
- (333.62 KiB) Downloaded 3216 times
Hy Larry,
The schematic posted are the 210C or 210H?
Hi 2308to,
I could not open your PDF, something going wrong!
sincerely, amporo
sincerely, amporo
The link to the pdf is almost ten years old now.
It might be 10 years old but the info is still useful. Is there anyone who could repost these schematics as I am in the same boat.
Yes, I can work from the JVM4xx versions but there are a lot of resistor/capacitor numbers at least which are different, and working across multiple pages of schematic is awfully slow when you have possibly incorrect component number references.
It looks as though the links to the schematics have gone up in smoke so I contacted Novosibir and he still has the originals. I've put each of the two into a booklet now so you can easily get the whole sequence for each amp series. Novosibir is looking at them and may repost them as permanent links on the original reference thread but in the meantime here they are from my own Dropbox site:
JVM2xx:
https://www.dropbox.com/s/4rnml6sulo68l ... s.pdf?dl=0
JVM4xx:
https://www.dropbox.com/s/n1gqurjb5eg1q ... s.pdf?dl=0
They should be available for a long time from that.
EDIT: I'm having trouble getting the system to recognise the addresses somehow if I put them inside its [LINK] tags. I've posted them as raw addresses but once again the system seems somehow to insist on doing that by itself. Hope these stay active and working.
JVM2xx:
JVM4xx:
