[quote="Jimy"] My only concern with that approach is that one of the under-board connections could come loose while you're soldering a component to the upper side of the turret. I have to say I'm not really crazy about this method of construction. It gives a really neat appearance but, from a maintenance and repair point of view, it's a bit problematic. I suppose that's why Marshall moved away from it in their later amps. Anyway, I finally got the board in place the way I wanted and made a few connections.[quote="Jimy"]
I have to agree. I have had a wire drop on my JTM45 board and my JTM45/100 causing fire up problems
. My 50 watter with visible links - with a 350 degree wrap around the lower half of the turret had no such problems
. Maybe because I used buss wire and insulation I did not wedge the wire in tight enough and when I dropped the components in and soldered I dislodged them.
Lessons learned, will not do on next build.
Looks great, glad it sounds as good as it looks
