Drum Software??
rockstah
Post by rockstah » Wed Mar 22, 2006 1:03 pm
NY Chief wrote:Excellent info, guys. Much appreciated.
My wish list is shaping up to be M Audio 1814, PT (M Audio version) Ableton or Cubase and some drum stuff.
Will I need a separate sequencer app to get drums to file for import to track or does the PT software include that? Obvioulsy I would need that if I used separate samples but what discrete and drumkit from hell, fruity loops...all that shit?
I also like what you said about just the I/O, Nitro. I'd like to try that Neve kit George has been playing with. If I did go that route I would use plugins to software for the pres or would I need hardware (like the kit)?
im not sure but if you get maudio the protools software is cheaper from maudio than the cubase will cost you. and yes pt does midi. discrete drums are samples
u would import into pt/cubase/nuendo
drum kitfrom hell is a midi instrument(VST or RTAS) you could use in pt/cubase/nuendo etc.
if you had hardware like the neve then you wouldnt need maudio card since it has pres - then you might want to go with RME stuff and just get a card with good ad/da converters and no pres since you have that in neve - ..see maudio 1814 has mic preas already. its all in one. - guys that want to use there neve's and other hardware mic pres just get a card to get audio in - ya follow me?
hardware like neve is all about mic pres and then you have card to get audio in
maudio stuff is all in one. gets audio in and has its own mic pres
Mark
Post by NY Chief » Wed Mar 22, 2006 1:55 pm
Got it loud and clear, Mark!!! Gonna be fun when I get it rockin'.
Now if I only didn't have to work for a living...
rockstah
Post by rockstah » Wed Mar 22, 2006 2:02 pm
work is good - how else can we afford these things? :)
NitroLiq
Post by NitroLiq » Wed Mar 22, 2006 2:28 pm
NY Chief wrote:Will I need a separate sequencer app to get drums to file for import to track or does the PT software include that? Obvioulsy I would need that if I used separate samples but what discrete and drumkit from hell, fruity loops...all that shit?
Not quite sure I understand the question. Most of the major packages like Cubase or Logic do audio and sequencing. I know PT does sequencing but I'm not sure how robust it is...PT basically started out as audio and they added midi sequencing features. The other packages started out as midi sequences from way way way back...before PT was a twinkle in some engineer's eye and added audio recording as technology got better. Most folks I know with the PT hardware/software setup usually use something else for sequencing.
With sampling CDs, depending on the CD, they come with wav or aiff files at the minimum so you can either import them onto an audio track or into a sampler (be it hardware or software). More advanced CD-roms will support different software sampler formats like any of the Native Instruments stuff (Kontakt, Kompakt, Intakt, etc), gigastudio, akai, Logic's EXS24, etc. Many of the soft samplers can work as standalone software or as a plugin (VST, RTAS, etc.) The audio/sequencing package you choose will support different plugin formats. So, for me, I use Kontakt as a VST plugin in both Nuendo and the old pc version of Logic Audio 5.5. Kontakt can read sample formats from many other vendors and you can tweak and mangle like there's no tomorrow.
If I don't really want to tweak anything and the tempo is fine, I'll just import wav files into audio tracks and arrange them like that...keep everything as audio. Or, I'll program a track, then actually record the VST instrument to an audio track (like a drum track where everything's coming from Kontakt). Then I just use other tools to split the individual drums out over several tracks
Spectrasonics has something called groove control on many of their CDs which basically is that, they've taken their loops and cut them up and created a midi file where each cut is mapped to a separate midi note. This allows you to adjust your song tempo without affecting pitch of the actual instruments.
You can also find plug-ins specifically geared for drums like Battery which also has libraries you can buy. I'm sure there are drum modules as well.
NY Chief wrote:I also like what you said about just the I/O, Nitro. I'd like to try that Neve kit George has been playing with. If I did go that route I would use plugins to software for the pres or would I need hardware (like the kit)?
No, you would need hardware. With any of these, you can't really utilize plugins while recording be it compression, mic pre, etc. (only on playback) ProTools CAN but you need their $$$ hardware. Look at your budget and figure out what you really want to do. Are you just recording one or two tracks at a time? Are you trying to put together something to record a fully miked band? That should determine your inputs/outputs. If i was putting together something I could use in a band situation, I would go with an RME Fireface800. If on a budget and don't need individual tracks, I'd run mics into a 16-24 channel mixer and take the output straight into any 2-channel audio interface > into whatever software, be it 2-channel or multitrack (if you were going to add additional parts to it). If you're only recording 1 gutar or vocal track at a time, then maybe I would build the kit pre and maybe an la2a kit clone so I have at least one "sparkling" signal chain.
rockstah
Post by rockstah » Wed Mar 22, 2006 2:40 pm
with my 002r and using protools 7 and or nuendo 3, with eitehr app i can use plugins in real time ( RTAS = REAL TIME AUDIO SUITE)- non destructive - during recording and no effects go to track after the fact whatever.
the rme fireface800 is killer
NitroLiq
Post by NitroLiq » Wed Mar 22, 2006 3:20 pm
Weird...I thought only PT supported RTAS....also though it depended on hardware. Interesting. I wonder if Nuendo 2 supports RTAS...All my plugins are VST or DX. I wonder if I can find an RTAS compressor to test out....that'd be interesting. The only thing is I'd WANT the compressor to be recorded.
rockstah
Post by rockstah » Wed Mar 22, 2006 3:25 pm
Nitro, pt is rtas and nuendo is vst ,- u can get vst to rtas adapter for protools and rtas to vst adapter for nuendo to be able to use vst with PT and rtas with nuendo -
digi has come along way with their stuff. it used to be to get real time affects you needed $ now u have it , somewhat anyway.
i have used vst to rtas adapter in pt to use vst plugins and it works for the most part although i think they still need to tweak it some to get full use of some of the vst plugs that dont work * all the way*. :)
rtas in pt like vst in nuendo - are the same as far as real time non destructive plugins.
i have no need to try and use rtas to vst inside nuendo since there seems to be way more plugins on the vst side available.
way more software developement and compition vst side of things.
which brings the point up that when deciding between these two one has to think of plugins perhaps. it leads towhat will get the job done. the only reason for such adapters mentioned here is if you run into a plugin that you cant use with your setup( i.e. a kewl plugin liek a drum program or whatever that only comes in vst or only comes in rtas. these days alot are coming eitehr way though) - i hate to say it but the vst side of things will be plentiful of things to try for different effect applications. on the digi side of things its not as plentiful. digi is cathcing up with all the compitition but as far as plugins, varity of plugins the vst side of things can keep you buys for a while.
Mark
NitroLiq
Post by NitroLiq » Wed Mar 22, 2006 3:33 pm
Hmmm...are we talking about the same thing, though? Let's say I'm cutting a vocal and I want to compress it to tape...er to an audio track in nuendo. Normally, I would use a hardware compressor to record the compressed vocal. I haven't been able to do that with a plugin during the actual recording. I could put cpmpression on the track and could hear it through monitors while recording but Im talking about actually using the plugin like this signal > plugin comp. > audio track.
Post by NY Chief » Wed Mar 22, 2006 3:36 pm
I'm basically doing a project studio level thing. Most I'll do live will probably be rhtymn tracks. Guitar, Bass, Drum, maybe keys and scratch vocal.
For now I think I'll go with the M-Audio box Mark suggested. Later on maybe I'll get a card and play with mic pres and stuff.
I took a look at the website for the Fireface. Holy shit that thing does look killer!
Thanks, Guys. I'll keep ya posted.
rockstah
Post by rockstah » Wed Mar 22, 2006 3:40 pm
NitroLiq wrote:Hmmm...are we talking about the same thing, though? Let's say I'm cutting a vocal and I want to compress it to tape...er to an audio track in nuendo. Normally, I would use a hardware compressor to record the compressed vocal. I haven't been able to do that with a plugin during the actual recording. I could put cpmpression on the track and could hear it through monitors while recording but Im talking about actually using the plugin like this signal > plugin comp. > audio track.
nitro exactly - with protools or nuendo you set up a track have a compressor on it inside each app - record your vocal and now go and commit it to track, edit the settings or remove it all together. non destructive compressor on your recorded vocal.
i edited my earlier post*
NitroLiq
Post by NitroLiq » Wed Mar 22, 2006 3:42 pm
Yeah, the RME Fireface800 is the bees knees....great converters on that thing and i/o galore. Looking forward to hearing the first recordings from the rig, chief.
rockstah
Post by rockstah » Wed Mar 22, 2006 3:44 pm
NY Chief wrote:I'm basically doing a project studio level thing. Most I'll do live will probably be rhtymn tracks. Guitar, Bass, Drum, maybe keys and scratch vocal.
think about the 410 over the more expensive 1814 - the 410 has two mic pres all youll need for your demo stuff. the 1814 has 4 mic preas alittle more flexable but ya pay for it - now ask yourself do ya need? :)
i know a guy thats done many cds with the 410 - it sounds good.
i went with the 002r because it has 4 mic pres and almost went with the 1814 after i was hot on getting a 410 ;)
Mark
Post by NY Chief » Wed Mar 22, 2006 3:45 pm
Can you guys recommend any good training materials? DVD's on the software use and such?
rockstah
Post by rockstah » Wed Mar 22, 2006 3:45 pm
cant lose with the fireface800
rockstah
Post by rockstah » Wed Mar 22, 2006 3:47 pm
NY Chief wrote:Can you guys recommend any good training materials? DVD's on the software use and such?
with any software app you chosee their are tutorials and some good ones out there that get ya busy.
these are for protools but many of its lessons are basic knowledge in any app u choose
http://www.digidesign.com/disk/diskflix/
