Leaded Solder
Bainzy
Leaded Solder
Post by Bainzy » Fri Mar 24, 2006 2:38 pm
Contains 20% lead. What are the safety precautions necessary when using this stuff? What harmful effects can it have?
I've tried soldering with it a few times and tried not breathing in the fumes, but it's no good - they linger in the room. I can't get unleaded solder this thin from my local DIY store, and it doesn't work very well either.
Shred Guitar
NitroLiq
Post by NitroLiq » Fri Mar 24, 2006 3:20 pm
Work in a ventilated area/near a window and open it a crack. Or put a small fan on low nearby to blow the fumes away.
JD
Post by JD » Fri Mar 24, 2006 7:01 pm
For the little solder points on an amp don't worry too much. Just don't eat any.
Higbean
Post by Higbean » Fri Mar 24, 2006 11:04 pm
Be careful!!!
That stuff will make your babies come out completly naked!
