THE HW Marshall thread. Tweaking it step by step.
- VelvetGeorge
- Site Owner
Here's the stock HW 100 watt. I put in Mullard reissue EL34's, the stock outputs were not sent with the amp. The preamps tubes are stock 12ax7s.
It's my typical chain:
Les Paul w/ '68 T tops > straight in > Power Brake, down 3 clicks > mid 70's straight cab with 25 W blackbacks > SM57 > N72 Neve clone > Nuendo.
No EQ or FX.
The clip starts with Vol on 10, all tone controls on 5. Half way through I turned all the tone controls to 10, but it squealed really bad, so I backed the presence off to 9.
EDIT I have attached a parts list for the tweaks I made, with links to the products in my store. VG
No EQ or FX.
- 1959 HW Marshall Tweaks.doc
- (20.5 KiB) Downloaded 6799 times
- Stock HW_03.mp3
- (1.86 MiB) Downloaded 9553 times
- Flames1950
- VelvetGeorge
- Site Owner
Just checked and the bright cap was already clipped on this amp. In person it is extremely bright. A high frequency hiss seems attatched to each note, that I can't dial out.
Beyond that, it sounds an awful lot like my '70 100.
Not bad, but lots of room for tweaking. More clips and pictures to follow.
- Bainzy
I'd say it sounds half way between the 1959slp RI and an amp with Metroamp parts or a real vintage plexi Marshall.
N72 preamp sounds great
Shred Guitar
Shred Guitar
- 77custom
- VelvetGeorge
- Site Owner
rockstah wrote:George,
which pickup is this?
sm57?
Mark
I have a set of T top humbuckers from a '68 SG in my LP.
The output is really low. They both measure 7.35k and lean more to the mellow side. If something sounds at all harsh with these, it will kill you with more common pickups.
- VelvetGeorge
- Site Owner
- novosibir
Hey Andy! Did you listen to the clip with regular computer speakers or have you connected a stereo system to your PC?Flames1950 wrote:Sounds OK. Doesn't suck but I'm not sure I hear anything "special" there either.
In my ears it sounds sharp and bity w/o chunk in the bottom. IMO a unreasonable demand for people, who are spoilt of the full and rich sound of the good old real ones.
Larry
- VelvetGeorge
- Site Owner
Tweaking ROUND 1
Here's the next clip. Here I have:
replaced the stock signal and presence caps with Sozo Vintage +
shortened and rerouted wires for less noise and no squeal
tightened down the choke mounting bolt.
No break in or anything. Just fired it up and hit record.
I also checked the B+. With exactly 120VAC coming in I have 470 on the plates of the outputs.
- HW w Sozo_01.mp3
- (1.28 MiB) Downloaded 7603 times
- VelvetGeorge
- Site Owner
- Bluesgeetar
hmmm
Amazing how the Sozo caps can turn it into a usable amp. I hated it before honestly. But now it is actually nice to listen to.
- Flames1950
Well, I'm listening on computer speakers....a Klipsch 2.1 set though, not terribly cheap junk, although I'm sure my old Infinity Studio Monitor series speakers would tell a little more of the tale. Plus the volume was lower since my son was in the room. I'll give both clips a listen now that no one's around for a few minutes.novosibir wrote:Hey Andy! Did you listen to the clip with regular computer speakers or have you connected a stereo system to your PC?Flames1950 wrote:Sounds OK. Doesn't suck but I'm not sure I hear anything "special" there either.
Larry
- Flames1950
Yeah, Larry, when I can crank it louder it gets more noticeable how "picky" the tone was, and a lot of extraneous fur to it as well......the SoZo's and lead dress changes helped a lot but I still hear a lot of fuzziness (I know, those SoZo's need to cook) but it is already clearer in the lows and low mids to my ears, and a little fatter in the highs......
But my opinion is also jaded a bit, I know I personally don't care for split cathode Lead spec, I want the Super Bass circuit or the early JTM45/100 sound.........
George, do you have license to simply to whatever it takes to make them great with these two HW Marshalls, cost not a consideration? OT and everything?
- 77custom
VelvetGeorge wrote:Tweaking ROUND 1
I like it better now. It's warmer and smoother than stock.
