Forming Caps?
kefestvog
Forming Caps?
Post by kefestvog » Thu Jan 11, 2007 10:52 pm
I'm starting to put together a JTM45. I've heard some people talking about forming caps. As I undestand this it has to do with bringing amp up to voltage with a Variac. How is this done? What do you gain from doing it? What's the minimum size Variac (500w or 1kw) that you need to do it? Any anything else I need to know about it. Thanks.
Post by NY Chief » Fri Jan 12, 2007 3:31 pm
mightymike
Post by mightymike » Wed Jan 17, 2007 9:36 am
That link has more to do with the "break in" period with the Sozo caps.
I think what this guy was referring to was, on first fire up of an old amp that had been sitting, or even a new amp's first fire up; The process of using a Variac (with the tubes pulled out and connected to a dummy load) to slowly bring up the wall voltage up to 120, to form or reform the caps.
A few people here do that, or somerhing similiar to that, and it's one of the many benifits of owning a Variac
The reason you do it with the tubes pulled because at real low heater voltage, you can mess up your tubes with cathode stripping.
I think Larry (Novisbir) does this, or something similiar.
novosibir
Post by novosibir » Wed Jan 17, 2007 10:16 am
mightymike wrote:The reason you do it with the tubes pulled because at real low heater voltage, you can mess up your tubes with cathode stripping.
Yep, the low heater voltage wouldt badly hurt the tube's cathodes.
But I'm not using a variac, I pull out all tubes and put a 100K resistor between the rectifier diodes and the entire power supply rail, so that all the caps will be charged through the 100K resistor with a very very low current and also with a pretty low voltage of about 200...230V at the beginning.
The voltage drop across the resistor becomes les and less - and first when the voltage drop is less than 10V across the resistor, the caps are formed.
With new caps this process will take about 3...4 hours - with long stored caps or NOS LCR's (which I'm using in my amps) it usually takes 8...12 hours.
Larry
Tubes
Post by Tubes » Wed Jan 17, 2007 12:28 pm
wheres the link...
novosibir
Post by novosibir » Wed Jan 17, 2007 4:28 pm
@ Tubes
All your requested infos you should get here:
http://forum.metroamp.com/viewtopic.php ... ht=forming
Larry
white room
Post by white room » Wed Jan 17, 2007 4:39 pm
Larry
Larry, I read your post on this subject, in another thread, last week and I want to make sure I have it straight before I do it.
On my 67 build, I would put the 100k between the diodes and the first mains filter cap, correct?
novosibir
Post by novosibir » Wed Jan 17, 2007 4:41 pm
Correct!
Larry
mightymike
Post by mightymike » Wed Jan 17, 2007 4:53 pm
Tubes
Post by Tubes » Wed Jan 17, 2007 5:14 pm
novosibir wrote:@ Tubes
Larry
Thanks a bunch! I missed that thread when searching the other day and today. :?
ritasamson
Re: Forming Caps?
Post by ritasamson » Fri Oct 22, 2010 3:35 am
http://forum.metroamp.com/viewtopic.php" onclick="window.open(this.href);return false; ... ht=forming
Larry
thanks for the info.
