Amp layouts, courtesy of BillyBatz
- MacGaden
- Wiki Editor
I´m the one hosting those layouts.....rockstah wrote:http://homepage.mac.com/gaden/Amps-n-st ... ing15.html
The 50 watt layout is not up there as far as I can see. That´s why I asked.
MacG.
- MacGaden
- Wiki Editor
Yeah its been working since you first sent me the links and passwords but for some reason I didnt notice the new network drive in my computer.
Flames, all the wires too and from the screens are clearly there but if you view it from a fairly zoomod out POV you may not be able to distinguish them. Zoom in a bit and you can see it.
- guitar007
Your right but I wasnt going to go digging for correct color codes because they changed even with the same amp model. And from what Ive seen the Metro Heyboers, OEI, and MM all have different color codes for the same trannys. Its easy enough to change them but you should use your trannys wiring schematic strictly.
- VelvetGeorge
- Site Owner
- MacGaden
- Wiki Editor
1672 huh? There must be a lot of lurkers here. Theres like 700 memebers now and maybe 50 post from week to week.
Can we keep tallies on innacuracies? Ive fixed the ones mentioned so far but I do want to try to keep the layouts accurate to marshall.
I know the filter caps on the main board have the resistor on the wrong side.
I think I may use the wrong sides for the V1 stages on some schems. I do most of these from memory of the schematics and I try and get it done quick obvliously. So please guy take a look at the new 50W schems and tell me if you see anything.
- novosibir
Maybe all my kids have downloaded itBilly Batz wrote:1672 huh? There must be a lot of lurkers here. Theres like 700 memebers now ...
Larry
