- sonoman1979
I think that maybe a should try to modify the input in the pcb in order to attach the 33k grid resistor directly to the tube socket pin, I remember that read somewhere that if not doing that way the amp could squeal. do you think that could solve the issue?
- herbvis
Can't hurt. I usually go with that method when its quick and easily reversible.
- sonoman1979
Ummm well all the modifications that I had done to the amp we're definitely not reversible
... so let's try that
- herbvis
Good luck to you.
Heres a link to a clip I made last night. I didnt spend any time dialing it in, but thought it sounded decent enough. Its the one on top called mod may21
http://www.soundclick.com/Herbvis
- sonoman1979
Thanks Herbvis, and that's a sweet tone
I really like how a 4x12 cab enhance the bass response, I wish i could buy one
- herbvis
A 4x12 really adds a lot. I was using 2x12 for a little while a few years ago because the was sick of hauling a 4x12 around all the time. When I switched back to a 4x12 things were much better.
- snakepit86
yeah herb!
here is my video again, last time forum went down
https://www.youtube.com/watch?v=SaUTSB1yrAM
- herbvis
Thanks man! Your clip sounds awesome!snakepit86 wrote:yeah herb!
My clip was a quick rough test. Im gonna fine tune my specs when I get a moment to do so, then ill make some more coherant clips!
Everyone's getting some nice tones
Here's my latest tweaks trying to reduce the high end fizziness and shape the mids a bit more. I've put in a JJ EEC803S in the phase inverter, which has helped quite nicely and added some sweetness and also cut some bass muddiness. Changed my presence cap to 0.15u MKT1813 instead of the 0.1u Sozo nexgen. Also got a GE-7 to shape the tone and gain a bit more.
http://sclk.co/s7ywdi
Nice work BRM. Is this based on the 34 spec?
Thanks. No, not really like a 34. More like a '69 superlead with two added stages not as cold as a 34 style.
New clip with new spec 69 lol,
with orig,
http://soundclick.com/share.cfm?id=13389891
without orig,
http://soundclick.com/share.cfm?id=13389935
with orig,
without orig,
New 69 spec,
scom full,
http://soundclick.com/share.cfm?id=13390436
NT full,
http://soundclick.com/share.cfm?id=13390435
scom full,
NT full,
Nigel, your best work yet, sounds just like the original .... this is 99,999987% there
Regards
Ragnar Már
'67 JMP 50W
'82 JCM 800 1959
'83 JCM 800 2203
'87 2554
'09 Metro JMP 2204
'10 SDM 2550X
'10 Metro JMP 2203
Ragnar Már
'67 JMP 50W
'82 JCM 800 1959
'83 JCM 800 2203
'87 2554
'09 Metro JMP 2204
'10 SDM 2550X
'10 Metro JMP 2203
Cheers man !RagnarMarGunn wrote:Nigel, your best work yet, sounds just like the original .... this is 99,999987% there
