Choke question
- toner
Choke question
Assume all grounding, lead dress, filter caps, etc. are good...
Can the choke be the only cause of ghosting? Has anyone fixed ghosting by installing a new choke?
I have found a fairly acceptable compromise between ghosting and the tone/feel I would prefer from lower filtering:
mains: 100uF
screens: 50uF
PI: 50uF
preamp: 50uF
However, there is still noticeable ghosting with neck pickups (Les Paul or Strat). I was able to almost eliminate ghosting by running 200uF for mains, but I didn't like the tone as much.
I know it's cheap to try a new choke but I'd rather not tear into the amp more if it's not likely to help. Any advice is much appreciated!
mains: 100uF
screens: 50uF
PI: 50uF
preamp: 50uF
- Flames1950
I tried swapping a 10H in place of the 3.3H that came with my Super Bass kit......the low end felt quite different, but alas, little help with ghosting even though you would think it would be a great improvement.
Anything that cuts lower frequencies can help keep your power supply from modulating and ghosting -- Lead spec with split cathodes and smaller couplers definitely helps compared to Bass spec, given the same filtering. Or lower output brighter pickups. Maybe even going to 2.2K screen resistors? Might cut back on screen current and help some but I haven't tried it.......
- novosibir
How felt the low end different?Flames1950 wrote:I tried swapping a 10H in place of the 3.3H that came with my Super Bass kit......the low end felt quite different....
Larry
- Flames1950
- toner
- toner
40HRebelsLG wrote:I compared 3.6H choke with 40H choke in my 2204 build. With 40H sound was more balanced to me. More pleasant to my ears. So I have chosen this one.
Does a higher Henry value act similar to higher value filter caps (tighter feel, possibly less ghosting) or am I mistaken?
