1959 2013 LP Build
vanhalen5150
Re: 1959 2013 LP Build
Post by vanhalen5150 » Mon Aug 26, 2013 6:47 am
I decided to not wax pot the pickups (yet). I wanted to see what they sound like without first. The bobbins on these are both cream coloured and there is a wood spacer.
vanhalen5150
Post by vanhalen5150 » Mon Aug 26, 2013 6:49 am
Installed pots and jack. Looks much brighter with a flash. Natural light has a more mellow vibe than what you see here.
vanhalen5150
Post by vanhalen5150 » Mon Aug 26, 2013 10:02 am
Better none flash iphone pic.
(879.63 KiB) Downloaded 419 times
vanhalen5150
Post by vanhalen5150 » Mon Aug 26, 2013 10:03 am
To get the pickup rings to bend a little, I heated them up in some hot water.
vanhalen5150
Post by vanhalen5150 » Tue Aug 27, 2013 4:58 pm
Pretty much finished. Needs a bit of work to the frets and the nut. Just put on an old set of strings to get the bridge on. Sound pretty good right now. Even not plugged in its loud with a lot of sustain. Neck is very straight.
In case your wondering how those old screw poles go in, you do this first. Tighten all three bolts together. You then can use a rachet type screw driver on the top nut down into your pre drilled hole.
Trouble getting the bridge to line up for some reason....what I didnt know was that on old LP's the stop piece is slightly angled as well.....yeah...its angled...I looked at the plans...its angled... :shock:
Anyways... i have a bit of adjusting to do with the bridge but it will come out ok. Another lesson learned. :roll:
vanhalen5150
Post by vanhalen5150 » Tue Aug 27, 2013 5:00 pm
vanhalen5150
Post by vanhalen5150 » Tue Aug 27, 2013 5:01 pm
vanhalen5150
Post by vanhalen5150 » Tue Aug 27, 2013 5:03 pm
vanhalen5150
Post by vanhalen5150 » Tue Aug 27, 2013 5:04 pm
Nut is shifted a bit. Havent glued it in yet.
TWANGGG
Post by TWANGGG » Wed Aug 28, 2013 12:40 am
Congratulations are in order here! :toast:
I'm simply in awe of what you've created, just incredible.
jimmyride
Post by jimmyride » Wed Aug 28, 2013 12:49 am
Amazing job!!! I wanna hear some clips now! :-)
vanhalen5150
Post by vanhalen5150 » Wed Aug 28, 2013 7:40 am
Thanks fella's. Really though its just about taking the time and not rushing things. I made a few mistakes here and there on this one but those are not to be repeated.
I''l try to get a decent clip up soon.
Post by Tone Slinger » Wed Aug 28, 2013 9:50 am
Awesome guitar :rock:
somethin'else
Post by somethin'else » Tue Sep 03, 2013 2:45 pm
OutStanding :clap:
Can't wait to hear it!
Could ya do some clean 12 Series clips too? Or semi-clean anyway.
Really interested in those StewMacs.
Man! That top carve is delicious!!!
And to think you started this in . . . March ?!!! Wow! Five Months! Smokin'... :rockon:
dave
syscokid
Post by syscokid » Sun Sep 29, 2013 1:33 pm
That is an amazing job, and the top is spectaculicious... :toast:
"When I'm on stage and first plug in, and I feel a rush of air in my balls... That's when I know my guitar is sounding good!" -Leslie West
